RCU Forums - View Single Post - NexStar Select Engine Issue - NuBee
Old 04-10-2005 | 06:35 AM
LuckyArmpit's Avatar
LuckyArmpit
Default RE: NexStar Select Engine Issue - NuBee
Air bubbles mean theres an air leak in the fuel system generally. Had this problem myself last week. Turned out to be a crack/hole
in the fuel line going to the needle valve. The line was torn right at the copper tube that hangs out at the fuel tank. I put a new section of silicon tubing on and bubbles disappeared.
Dave...
