I wouldn't bother with it on a 4*, just use the hardware that comes with the kit (or ARF).
Pull/pull is often lighter than a control rod; it can actually give you more precise control, because the servo is always pulling the control surface, pushing on it under flight loads can cause a slight bend in a pushrod; and pull/pull is just cool.
Hope that helps.
Dennis-
