RCU Forums - View Single Post - help on my rush evo
Old 04-10-2005 | 08:38 AM
rush basher
Default RE: help on my rush evo
I know its a bit late if you only had an hour after posting, but (apart from the fact there is no picture) masher 2k's would be fine on any 2.2' wheels. Make sure you get a front set and a rear set of wheels though. The fronts wil be the same bearing setup for all 2wd trucks, and if the rears are hpi wheels, then they will fit on the hex hubs fine. If they are associated or proline, just take the hex off and they will fit directly on the pin...
