RCU Forums - View Single Post - NexStar Select Engine Issue - NuBee
Old 04-10-2005 | 03:01 PM
Pilot Chad's Avatar
Pilot Chad
Default RE: NexStar Select Engine Issue - NuBee
You really have to be careful with that wind. It will REALLY knock your plane around in take off. I learned that the hard way today. In takeoff another thing is that if you have a split second to think of a reason not to go up wind espeacially, I highly reccomend you go to idle and let it run in the grass or whatever it takes to keep it on the ground. I had a split second and thought i could make it. The crosswind was fine for me and i easily got through it, but then the wind changed and gave my plane a little boost of lift causing it to go vertical and tip stall
STUPID STUPID STUPID
Just be careful with wind, and don't give too much elevator.
Today was the winds fault, last time it was mine
