RE: veco 19 tuning and running suggestions
Yes, i agree pressure would help, if putting a fitting into the crankcase would work, im all for it, if i can find a fitting. lol The baffle is the holdup i think, I was also looking at some other used engines, are all 19s the same for motor mount wise? Also will the other sizes fit the same motor mount? 19-25 is the suggested engine size. I played with it in a big puddle from our rain today, and just went on low throttle, and it was great, i cant wait to get it running good so i can trust it in the middle of our lake! =)
Im awaiting a veco 19 profesional here, there should be a way to make it run full throttle with the baffle isn't there? I mean, they wouldn't make them with just a baffle if they couldn't be ran, right? Does the baffle need to be adjusted or something. I have the fuel tank right behind the engine, almost touching it level with it, because it was lower and didn't want to work. Its there temporarily though, i hope to be able to put it back below the engine were it belongs.
Brian =)
