RCU Forums - View Single Post - Great Planes Tiporare – Thirteen Year Build
Thread
04-10-2005 | 07:19 PM
18
8178
My Feedback: (
17
May 2004
4,351
Atlanta, GA
RE: Great Planes Tiporare – Thirteen Year Build
After a lot of hand wringing on how to create a removable loop in the main fuel line, for fueling the tank, I came up with these ideas and settled on the brass loop. That’s the right hand image below. The main fuel line from the tank will project out from behind the engine flex mount, connect to the loop and then another line will go back to the pump. The loop will be easily accessible behind the engine. I didn’t have much luck bending the brass tubing into a loop, so I cut up three pieces and hi-temp sliver soldered it together in a loop. After cleaning and polishing the outside of the loop I ran it through a ultrasonic cleaner a few times to make sure the inside of the tube was clean and pressure tested it under water.
To be continued…
Reply
Like
8178
View Public Profile
Send a private message to 8178
Find More Posts by 8178
View iTrader Profile
