check valve on pressure line?
I have a new Saito 150 I am about to break in and I read about a guy putting a check valve on the pressure line from the tank to the muffler. Apparently this will pressurize the tank at higher throttle and then keep it pressurized at lower thottle settings.
Does this work? Or will it make the low end run rich?
