RE: check valve on pressure line?
i think if you put a check valve in without a regulator it might run fine untill you drop throttle and then it will be rich because the pressure will be shoving the fuel to the carb whether it wants it or not, and if (when) you kill the engine you will have a mess!
Good luck
