RE: Impact
Hi Eric,
Interesting about your left aileron trim.
I was about to glue my wings in place before I decided to remeasure one more time. This time I measured my wing incidence at 3 places on each wing panel . The left hand wing panel looking from the rear was spot on, however the right hand wing panel measure perfect at the root and mid wing span. When I measured the tip I noticed that the my wing had a slight twist by just over 1/8th of a degree therfore the measured incidenceat this point was +0.1 degrees instead of +0.25.
Since there is little I can do with the wing l have decided to install a rear wing adjuster as I felt the only way to get it right was with flight trimming.
Interesting thing is my model would have had the same trimming correction as yours.
I will take aboard your comments about the front wing bolt. If you get a chance a picture of the front wing bolt area would be great.
How does it rate now against the Pinnacle?
Peter
