RE: check valve on pressure line?
I Tried it once and ended up with a totally erratic needle settings on the low end, usually on the rich side. Settings would change as the tank emptied. Constantly chasing my tail! If you need to do it , get a regulator, if not, leave it alone. Another thing to keep in mind, you have to un-hook the valve to fill your tank.
