RE: Engine bearing leak??
The front bearings often weep as they are not a proper sealed bearing and the crank is designed to "pump" oil to the bearing using primary compression, so its often forced out the front...
The actual seal to the crankcase is made by the oil around the crank and the close tolerance, however, if the front bearing is shot then the crank will be wearing away at the tight tolerance crankcase..
[X(]
