RE: GY401/9254 servo..Should the tail be locked in solid in hover?
Ok,,,,i'll try dropping the sens down a little....gyro is mounted in front per manual and I used one square of the double sided tape that come with gyro. No revo mix, No training gear. Trim is centered and t/r arm is 90 degrees to linkage and it's started up in HH and when I move it after starting I do the l/r rudder input 3 times quickly to reset center. Thanks!!
