RE: Engine Lacks Power
Are the ATV's or end points equal on both sides of the throttle? If not then 3/4 stick isn't 3/4 throttle. If you used atv's or endpoints that are more than a couple percent different then you've introduced differentail throw into your throttle and that should really be fixed before you go any further.
