RCU Forums - View Single Post - add split flaps to strip aileron wing?
Old 04-11-2005 | 04:53 PM
Tall Paul
Default RE: add split flaps to strip aileron wing?
Certainly the simplest fix.
I'm presuming "ailerons full up" means the side that usually would go up to command a turn to that side doesn't move any further up, while the other side goes down, lessening the drag on the downgoing side so the up-aileron's drag brings the nose around.
