RCU Forums - View Single Post - veco 19 tuning and running suggestions
Old 04-11-2005 | 07:23 PM
87gtmustang
Default RE: veco 19 tuning and running suggestions
Thanks!, i like my muffler too. I took it to the lake today, and it ran great! It was a blast. It was a little windy, or I mean alot windy, but I found a marsh like area that wasn't part of the big lake that I zoomed around on. I only had to retrieve it with my waders once, cause I hit a big wave or clump of weeds, something, and it ramped into the air and took a nose dive into the water and drenched the carb with water. =( It worked fine with the tank below, no problems at all. The only problem is that since I cant adjust my idle anyway without the butterfly exhaust, it runs a tad rich at idle, and is hard to start, but once you figure out the trick, it will start before long. Ironcross, it is a screemer! It was really fast and got to the point were it was barely touching the water at all in the back. It kind of bobs up and down when at high speed and barely on the water. Is that caused by the degree of engine tilt? How can I fix that if anyone has an idea. I built the mount myself, and it has about a 6 degree upward slant.
Brian =)
