RCU Forums - View Single Post - What is wrong with my 58
Old 04-11-2005 | 08:39 PM
David_Moen
Default RE: What is wrong with my 58
Could be that you are flooding the engine while priming it to start. Generally the Low speed needle (the one closest to the engine itself) should be 1 2/3 to 2 1/4 out from fully closed. Set BOTH needles at 2 turns out and see how that works. The clear tube connected to the nipple on the crank-case gets connected to the fitting on the carb closest to it - this is the fitting on the BOTTOM of the carb if the engine is held with the spark plug pointing up.
