RCU Forums - View Single Post - Range issue, could use some help
Old 04-11-2005 | 10:30 PM
  #34
George
My Feedback: (57)
Default RE: Range issue, could use some help
Sean, are you using any type of new "gizmo" or equipment that you haven't used before? Did you pull the equipment out of the Bar and stick it in the Euro or is it two separate sets of equipment giving you the same problem? If it's the Bar equipment just swapped to the Euro and you have the same issues, it's got to be some peice of the package and you need to figure out which component is the culprit.
BTW, I just maidened my Euro with the Merlin. My range check was good engine off and engine running with only about a 10% degradation but the overall range was less than what I have had in the past, but still plenty and more than my least range finding a few years back.
Hope you get it figured out, I'm sure you will.
Talk to you soon,
George
