RE: Question on Nexstar select issue.
Also, if your rudder servo is not 90 degrees to the servo, you need to move the servo horn, so it is. You will also have to adjust the EZ connector on the servo horn so the nose wheel is straight. Most nexstars seem to have this too.
Its just an ajustments, no big deal.
