RCU Forums - View Single Post - GY401/9254 servo..Should the tail be locked in solid in hover?
Old 04-12-2005 | 09:21 AM
blackmonte's Avatar
blackmonte
Default RE: GY401/9254 servo..Should the tail be locked in solid in hover?
Ball link is 13-13.5mm from center of servo arm. Engine is still a little on rich side. I have been gradually leaning it out. Engine has 9 tanks through it. Rpm seems to pretty good but I don't have a way to check it yet.
I will try adjusting the ball link on the t/r and see if that helps. And I will also try dropping the gain down in the radio from a 100% to 80% or so........Thanks!!
