RE: Problem with side views?
I'm guessing that the Full size plans would call out the dimensions as well as showing the locations. As you know, paper expands and contracts so you need a common reference when constructing the plane. Once this reference is established you can provide the correct dimensions to the stations along the reference line. Having never seen a set of WWI plans in Full Scale I am only hazarding a guess.
