RE: Tamiya Sherman Full Function
I have all 4 WWII Tamiya Tanks as does tomzag... FOr a FIRST TANK you cannot beat the SHERMAN...Easier to learn on than the PERSHING....THe Pershing or LEO2 should NOT be a first tank...It will frustrate the HELL out of someone who does NOT have a lot of r/c car or plane experience DUe to the LACK of SPACE inside...Monkey Bone....Look down in the Tank forum at the inside GUTS of my Pershing...NO ROOM for anything...VERY TIGHT FIT>>>> it is NOT impossible to build/assemble just LOTS of Patience... THE SHERMAN is SOOOO Roomy compared to the Pershing... DON't be strayed from the SHERMAN...IT IS AN AWESOME TANK and is legendary...follow my build below..I am assembling one as we speak.... You want to use the 4 Channel Radio so you will drive , turn shoot the 105 mm Gun and the machine gun , also rotate the turret and also has lights!!! really cool.... You can use a Futaba system and it Plugs right into the Multifunction Unit...EASY!!!! So don't stray... Get yourself the SHERMAN and ROCK on!!! YOu can call me if you;d like ...SPeaking on the phone is easier at times... private message me your phone # if you;d like and I will call you...I am off work today...
Happy Tanking..
