JHH Mirage Help
Sparky,
Its been a while since I was a teen. The Junior in the profile refers to your # of posts I believe. It lists you as a junior also. The engine I have is a 9101 rear intake and rear exhaust. I also have a Picco .80 in a Dynamax fan or a Rossi .81 witha Byron fan that I could use. I just figured the turbax and 7.5 would be fine since that is what it was designed around. I have the foam wing. It is already sheeted except for the center section on top and bottom. Does the bottom center on your wing stick down lower than the wing panels. My wing does. The pictures in the manual seem to show a flat bottom wing. Without the plans, I am not sure if mine is correct. I am using Spring Air gear. There is one servo pocket cut out in each wing panel for elevons. I am trying to find some time to start working on this thing to get it flying. I have a Byron Mig 15 and a Century Jet BAe Hawk that I am working on also. There just doesn't seem to be enough hours in the day to work on all three. I can take some more pics if that would help you out any. I believe mine has the Kfir long nose on it. I am going to build it as a Mirage 2000 I suppose. Thanks for the info.
Mark
