RCU Forums - View Single Post - ABC...wrong break in?
Old 04-13-2005 | 12:22 PM
  #120
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: ABC...wrong break in?
ORIGINAL: Flyboy Dave
The K&B manufacture site states that the engines should be launched in a four
cycle mode.
Here is what the K&B site says (bold emphasis is theirs, italics are mine):
AIRBORNE BREAK-IN
1> BREAK-IN running should be done with the recommended propeller at a slightly rich setting. You want the engine to be at running operating temperatures. The needle valve should be set at a point just into this range from a four cycle setting. Fly the plane at maximum throttle for 2 minutes, then throttle back to half throttle for approximately 30 seconds. Repeat this sequence until approximately 20 minutes of accumulated running time has been obtained...
