aaaaaaaaa... now what do I try ???
I'm starting to get annoyed here !!!!!
(MVVS 35cc red head gasser) (this motor has only been run for about 1&3/4 gallons)
so if you remembered my carb has never pulled/pumped fuel as it should,,, so today I took the carb down and had the chain saw shop guy replace the gaskets (he has been working on these Walbro carb's for 10 years, so I'm sure he know's what he's doing),,,
well,,, it still will not pull/pump fuel !!!
1) there is NO leaks in the fuel lines or any other line !!!
2) I get a pulse !!!
3) pulse seems to be strong !!
4)pulse tubing is new !!!
5) no leaks on the pulse line !!!
6) I have a new gaskets to seal the carb to the manifold !!!
""what do I try next ??!!""
Jim
