RE: aaaaaaaaa... now what do I try ???
it is NOT a plumbing problem, the fuel line work's great !!!!!!!!!!!!!!!!!!
I have even tried it with a new line and a cup of fuel !!!!!!!!
I took the carb back to the shop,
my friend remover the diaphragms and he took a flat jig type gauge and set it on the carb, then took a flat tool much like screw-drive, and he adjusted the height of that flap on the spring (he checked it and adjusted it a couple times), then he took a small hand (air) pump and hooked the hose to the fuel nipple and he pumped, the gauge on the pump went up to 20 pounds, when he pushed on the flap on the spring the air in the pump was realest,,, he now put the carb back together,,,
at home I remounted the carb and it still wont pull fuel !!!
Jim
