RCU Forums - View Single Post - First build - Sig SE started
Old 04-13-2005 | 07:08 PM
  #89
tychoc's Avatar
tychoc
Default RE: First build - Sig SE started
krossk: In another thred, the advice was that the windex/squeege method doesn't work with Ultracote. Only with Monokote on Monokote or Monokote on Ultrakote. That's why I didn't try this method.
I will try the windex method on the remaining trim too see how it works for me. Thanks for the info.
inverted flyer: In hindsight, I should have done the same and only had seams on solid surfaces. BTW, the blue on the leading edge on my wing is not overlaying the white (except for the seam) since it's over a solid surface. My bubble problem is on the wing tips where the blue is overlapping the white.
-tychoc
