RE: Question on Nexstar select issue.
I disagree with removing the anti-spin devices. The AFS has limited value due to its limitations in an acceptable range of ambient light. The speed brakes are not of particular value unless you are flying in tight confines -- in that case they permit a steep approach at a safe speed.. The Anti-spin devices, however, are very usefull for novice pilots. The plane flies & lands safely at a noticeably lower speed than without them.
I believe that Bayou Talker is speaking as a person who has prior experience -- not a complete beginner. Of course the aids are of no use to him -- he is already past the point where he needs them -- that is not the case with most new pilots. Hobbico knows what it is doing with this excellent trainer. Try the aids and discard them as you grow out of them.
