RCU Forums - View Single Post - How do I? Removing LST's reverse&Low
Old 04-13-2005 | 11:34 PM
icenutz's Avatar
icenutz
Default RE: How do I? Removing LST's reverse&Low
ORIGINAL: srad30
Icenutz, Are those spacer in place where the gears used to be, they look brassy like
What are they? It looks different from first posted pic
I just do not like the forks because I have had them slip out so I can not trust them anymore. In my pics copper tubing was used as a spacer. I am not sure what inside diameter of the tubing is but it fits perfectly snug over the gear shafts. SnortonLSTrules also used aluminum tubing inside the copper tubing to accomidate the where they shaft is smaller. Once again I am not sure what the inside diameter is but it fit snug over the shaft and inside the brass tubing. I have run over a gallon thorugh with no issues.
Just so you know a forward only conversion kit from Losi will be avaialble but not until June at the earliest. It is listed around $25.00.
