ORIGINAL: gjeffers
CeeGee, i will post pics and comentary as i build of everything that is not in the manual
Well, Here's where I started on the new UCD. I'm starting with the fuse since it's easier to do the fuse build before putting on the tail feathers. Last time I built one I followed the manual and the tail got in the way everytime I needed to roll it around. Anyway, my first UCD nosed in on the 3rd flight and one of the things that happened was it broke out a section just aft of the firewall, the section that looks like a ramp. Fortunately when it broke it out it gave me perfect access to the landing gear section and the inside of the firewall so on this build I cut out that section. Here's the pictures............
It takes a little doing to get it cut out but it allows really good access to the landing gear block to beef it up and the firewall. I use Gorilla glue to beef up the landing gear area and also to strengthen the firewall some.....Also you can change the T nuts to re-configure it for a different mount or even change the "ramp" configuration for a larger fuel tank.
[8D]
The last picture shows it ready to be re-glued back in with epoxy...........
