RE: set-up help with hb2
Try this, once the ESC is armed (LED solid green) try moving the throttle trim to full up. If I'm using the Esky TX my HB2 won't lift unless I crank the trim. Anymore I just use my Futaba 7CHP with the HB2. That way I can mess around with the throttle and pitch curves.
Also, I've read a few posts where folks have said that the 1500mah li-po's are a bit heavy for the HB2, but that's just hearsay. I'm using 1200mah li-po's and it fly's great!
