ORIGINAL: piper_chuck
SLOPPY RICH MIXTURE running is characterized by a very slow, irregular, sputtering exhaust sound. The exhaust gas will be very smoky and contain many droplets of oil. NEVER RUN AN ABC ENGINE AT THIS SETTING. The cylinder is not able to heat properly and the fit will be ruined in a short time.
RICH MIXTURE running is characterized by a slower, sometimes irregular, sputtering exhaust sound. The exhaust gas will be smoky and probably contain small droplets of oil. NEVER RUN AN ABC ENGINE AT THIS SETTING. The cylinder is not able to heat properly and the fit will be ruined in a short time.
FOUR CYCLING or SLIGHTLY RICH running is a rich type setting, but it is fast enough to pull the airplane. This is the setting you normally look for before launching the airplane because the engine will run leaner when airborne.
PEAKED OR TWO CYCLE. As the main needle is closed (clockwise), it reduces the amount of fuel mixed with the air drawn into the engine. At a specific point, which varies with each engine, air temperature, altitude and relative humidity, the exhaust note will change quickly into a smooth, powerful note. If the needle is closed further, the note will stay smooth, but will weaken. The peak occurs just at the break point from a rich setting and further leaning will ruin the engine. A lean setting raises the engine heat above the safe point, reduces lubrication, and destroys glow plugs due to high combustion temperature. This is very harmful to the engine and your investment. Learn to tune the engine before flying. Remember, a little rich is always preferred for long motor life.
Chuck,
If I understand this correctly, the settings above are in order of richness; from the richest mixture to the leanest (not including a damaging lean-run...).
If so, what is described here as 'FOUR CYCLING or SLIGHTLY RICH', is not what I mean when I talk about four-cycling, in which the engine actually fires on alternate revolutions.
This will actually happen when the mixture is 'RICH', or even on when 'SLOPPY RICH'.
Maybe the different understanding of this term is what prompted Profi to use it in their break-in instructions?
My definition of 'SLIGHTLY RICH' means the engine is clearly firing on nearly every revolution, yet is not peaked and it does emit a smoky exhaust, with some unburnt fuel and oil droplets.
But calling such a setting 'FOUR CYCLING' is a bit misleading, or rather completely misleading.
I believe you will agree on this issue.
