RE: 1.60 OS issues...
I think I will start with the remote needle assembly and go from there... After I make sure all that is clean and sealed I will try running it without the pump and see if I can get it to run better... The worst part about it is I have to drag it to the field every time because I can't get it to run poorly on the ground...
