ORIGINAL: SexyPizzaMan
Will this size motor 2812-0650 pull a u-can-do-flight flex 3d airplane??
- Jeff
Yes it will and then some depending on the AUW. Mine came in @ 14 oz. and am using the smaller 2808 0980 out runner with a 10/3.8 prop. Plenty of power and you can get away with the Pheonix 10. With a TP 1320 3 cell LiPo it gets 20 minutes per pack. What I did was add another mounting stick, glued to the stock one, as the out runners put the thrust about a half inch off the line as it was designed for a geared set up. Also with the offset, the cowl now lines up. The first thing I did was to get rid of the cowl. Joe
