RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-14-2005 | 08:54 PM
  #1773
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Here's an update on the build modifications....... Another one of the nice things about taking out the "ramp area" aft of the firewall is being able to fit the fuel tank easier. Mine had a misalignment in the bulkhead where the upper part of the tank goes into the compartment. Once I trimmed it out I was able to fit it in nicely...... You can see from the pictures that at this point if you wanted to modify the compartment for a larger tank it would be easier to do. Next I'll postion the throttle linkage and I'll be able to see the fuel tank and avoid it..........[8D] After that the "ramp section" is ready to glue back in and I'll get on with mounting the engine.............
ID:	258318   Click image for larger version
