RE: U-Can-Do 3d 46?
Hey CeeGee it looks good!!.. Nice tight fit... Are you adding foam to the saddle
bottom and back of tank? What did you use to seal/cushion the front of the tank?
I just used silicon adhesive.. Works great..
With the ramp out it also makes getting the throttle linkage nice and stright if
any adjustments are needed.... All's looking good!! Keep it coming...
I'm not sure how many are/will be using pressurized fuel systems.. But I have
gotten into a habit of putting drain holes, Then C.A.'ing or painting it where I think
the low spot is at in case of a tank problem which will make it easier to spot...
