RE: U-Can-Do 3d 46?
kokamo... A few fields are like that on 3D flying... Can't we just get along:-)
Most the time it can be worked out between the pilots with "a lot" of talk
and consideration for eack other... My field is pretty good about it:-) Right
now I'm about the only one that's 3Ding. On the Freq. pin and I.D....
Some fields are really strict on the rules... And for good reason, if you ever
lost a plane because of it.... Our's was the same on AMA or Club card, which
worked at times, But now we made up cards with our names on them, which
we leave in the freq. box and it seems to be working great, But our
membership is not big..
I have about 360 on my plane & setup, The UCD/YS63 was used but in great
shape I did repair/recover the wing tips with 4* red..
CeeGee.. Yeah foam does help, I did not use foam when I started on my Avistar
and had no problems, But I use foam now... On my Dazzler, It had foam around
the Tk./firewall.. But after a while it got soaked with fuel.. Then members told me
about using silicon to seal and hold the front of the tank..
