RCU Forums - View Single Post - Does length of feul line matter?
Old 09-27-2002 | 01:18 PM
kgough's Avatar
kgough
Default bad tank?
If you are having fuel supply problems, you should still be able to get it to turn over.
If it's flooding, close the needle valve, and spin it for a while. The excess fuel should clear out, and it will start up.
If it's too lean, prime it more, it should start.
If it runs for a few seconds then quits, maybe you have a tank problem.
If you can't get it to run at all, it's probably not fuel.
When I get stumped, I look for carb air leaks, try a new glow plug, then try a friend's glow driver.
Good luck.
Ken
