Does length of feul line matter?
12 inches is too much fuel line. If you "MUST" have that much line I would recommend that you get a cline/perry fuel pump or for a unreliable alternative, put a check valve between the muffle and the tank pressure line. This should keep a higher than atmospheric pressure on the tank to help force the fuel through the line.
