Thanks for the flight report Eric, those are very helpful tips. I changed out my tailwheel assembly for a 3rd party CF tailwheel from the start. That was the same tailwheel they had on the DV and it just don't cut it.
I haven't notice the issues with the stab tubes, but then again, I haven't had the engine running yet. I'll have to note that issue and check for the problem.
I'm using the HS5995TG servo on the tail, which is strong as a horse and superfast... I'll have to see how it holds up to the big barn door rudder's needs.
Thanks again for the details on flight characteristics. It really helps to know what to expect and also to know if mine is behaving "normally" for a Vision. Sounds like it's going to be a good time... wish me luck!
Tom
