RE: Chip Hyde's Vision 3D
Tom,
Unless you moved the C of G way back you probably wont need the nose weight. Probably best just to keep it in till you find your feet with it though.
Yes, it pulled left during prop hang and vertical climb so I will increase the right thrust a bit after ive flown it this weekend.
Eric,
You obviously like the Mejzlic 23X8. Have you compared it to a Menz S 22X8 (what im running). The Menz seems like a good prop but I dont like the way the prop hub compresses as you tighten it up.
Looking back at this afternoons flying the thing that sticks out is just how easy it was to fly. I only had two flights but I can envisage being able to do some pretty aggressive and hence more impressive freestyle routines than other 3D models ive flown. I wont be wanting to go back to the F3A at this rate!
Angus
