Here's the instruction sheet. This is for a 1.80. The only thing that changes is the recommended prop size (I recommend the Bambula 18x8 for 1.80, Menz Ultra prop 20x10 for 2.10). Also the break in RPM is 6500 for 1.80, 6000 for 2.10).
http://www.rcuniverse.com/forum/upfi...34/Xv64158.jpg
Most starters do not turn over these high compression big bores. The instruction sheet recommends flipping the prop to start it. Very easy once you master it.
ORIGINAL: serge760
thanks
how do you break-in a moki and what prop do i use
can i use my starter to run the engine??
