Great Planes Easy Fueler
Yeah, while they are very convenient, they leak all the time. And a leak between the carb and the tank will end up with a crash, sooner than later. Do the third line thing. And close the carb to zero throttle before you fuel. You should not have a flooded engine when you fill. If the thing is on a third line and it leaks, it does not matter...
