RE: need help now!!!...tonight!
Me thinks it's your gear mesh. Sounds like the motor is pushed too hard agaist the spur gear making it bind between the teeth. I've had that same problem when I went with a larger clutch bell because the clutch bell with more teeth has a larger radius. THe 15 tooth bell has just enough room to fit.
