RE: 8 ft of bones! Sr Telemaster
My wing is a one piece wing. The change I made was to eliminate the rubber bands by using a pin on the front and two nylon bolts on the trailing edge. The problem with making it a two piece wing is that the center section is not very substantial. There will have to be a good bit of extra material added to the center section to strengthen it. I used the standard rudder and have had no directional problems. The elevator requires a high torque servo.
