RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-17-2005 | 10:02 AM
  #1794
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Raideron, It looks like the loop is about the same height as the tank lines. It didn't leak before so hopefully it will still hold. If not I can put a longer line it to make the loop higher.
Goldenclan, I didn't install a tail wire set up on the last one and didn't have any problems with it. I may get around to it on this one but I'm not sure what type I would use. I have about 1000 feet of kevlar cord / string that would be perfect so maybe I could use that somehow. Hmmmm....... [:-] I'll have to think on that one.
Oh Man!![8D] I'm just about done with this one. Just have to hinge the control surfaces and a few other simple things. I'm trying to decide if I should use pinned hinges or the CA ones. I've never had any problem with CA hinges failing and I not sure how to install the pinned hinges. Any suggestions??
I might get to maiden my Twist today. Yesterday the monsoons were upon us. Who's ever praying for rain can stop now. [>:]
