RE: need help now!!!...tonight!
In that car the mounts are part of the crankcase. It's all preset if you still have the original .15FE engine in there. Just buy some motor mounts and use that instead of the built in ones and reset the gear mesh. If you run it too tight you will definitly destroy your new spur gear.
