On this side of the pond
you can get Giles 202 and various versions of the Typhoon (2000, 2+2) from Gator R/C. They also sell foam cores, cowls, pants etc for their plans. They also have plans for the Fascination, another (almost) 2X2 design.
MK has just released the TopStar kit which is an all balsa 2X2 pattern kit and is MUCH more reasonably priced than their other kits of the same size.
Falcon Hobbies (in Canada) sells plans for the Legacy (and foam cores if you wish).
There is another design, the Boxer 1.20, but I'm not sure of the current availability of the plans for this.
I build from scratch frequently ('cause I like to) and another avenue is to enlarge plans for .60 sized pattern planes such as the Loaded Dice. MK also kits the Alliance CP (for .63 4-stroke) - you could enlarge the plans for this - cheaper than the ZNLine kit
Hope this helps, good luck!!
-Will
