wing weight
if it'a funfly plane I usually don't like to correct it. I try to keep the funfly planes light. if it's a little off i use aileron trim to work it out. If I have to add weight I rather add the weight closer to the fuse rather than further out becaus the further out the more likely to cause a tip stall.. at least on the slow flying funfly's.
