RE: Insight build...another wood roach.
Waco was great...now back to work. I didn't get much done tonight...still recovering from extra Sunshine at Waco.
I made 4 lite ply donuts with 4-40 blind nuts for the attachment of the motor mount to the firewall. I then temporarily mounted the back part of the motor mount. I did this now because it will be a little more difficult to get to the back of the firewall later when the front part of the canopy section is glued in place...starting at the back of the firewall.
The canopy section is ready to glue on at the front and back. I masked off the fuse at each end to hopefully keep the glue off the bottom, middle section of the canopy. The middle will be cut loose (see cut lines) after the glue is dry at the front and back ends.
