Futaba
Hi Todd,
I am currently setting up a BobCat on a Futaba 9ZA radio. The gyro set-up is really simple. The gyro gain is on Aux 1 and then mixed using the P-Mix function.
Set up Retracts as master and Aux 1 (gyro gain) as slave. I am using the GY 351 gyro. I assume that your radio is the 9C. I use on of the rotary dials to fine tune the gyro and then disable it (the dial) when the gyro gain feels good.
If you are using a JR gyro, make sure to test it a bunch before flying. Some people have problems with JR gyros when used with Futaba radios.
